I have about 21hrs of flight experience with a Spark and a Mavic Mini and I am now expecting a
Mavic Air 2 on Friday
mavicpilots.com
Since you live in France, there are specific laws and rules for you to follow, please check to ensure these are current.
According to FCAA, drones are allowed in France, subject to FCAA and EASA regulations. Read on for details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini and the
Air 2, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
At DJI Download Center, Learn aboutMavic Mini
www.dji.com
Air 2
www.dji.com
Happy Droning…
