Hello
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum! :)
Greetings from Birmingham Alabama USA, welcome to the forum!
glad to join the forum as a new (but not young) pilot (mini 2 and soon mavic 3 classic).
Since you live in France, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Happy Droning…
Thanks
Dimension Drone AZ
