The app isn’t saying you are in a NFZ. It’s advising you that there’s a couple of bases nearby. It’s advising you that it’s not good to fly because you have got the temperature settings set too high.
Go into the settings menu and lower the setting of the temperature to say -10 and you will be good to fly down to -10. Obviously if the temp drops to -11 then the warning will pop up again.
As for the heliport and seaplane bases, you can turn off the notifications for these in the settings menu as well if you live more than 0.6km away from one.
The heliport will be Hamilton Hospital, I’m not a heli pilot but I would think their approach and take off to be towards the Bay Area, away from populated areas in case of engine failure.
I don’t think you will have any trouble with the seaplane base as they normally take off over water, again away from populated areas.
ALSO. Configure the settings in the app to give you the wind speeds at the height you will be flying. I have mine set to tell me what the wind is like at 413feet, including gusts (I already know how windy it is at ground level cos I’m stood there). You don’t need warnings on upper airspace cos you aren’t flying at aircraft heights (or shouldn’t be). Just play around with the app settings and customise it for what you want it to warn you of.
Last but not least....If you are actually in a genuine NFZ, you won’t even be able to start the propellers let alone take off.
I’m at work at the moment, so here’s a screen shot of mine. It’s saying that it’s not good because the cloud cover is 100%, (my setting was 95% so I’ve changed that now) it’s saying that the wind speed is 9mph at 413feet but with gust of 31mph (I have the warning set at 20mph) so it’s actually good to fly as long as I’m aware that it’s very cloudy with occasional gusts of wind and check that I have sats locked.
Regards Brian
