Help Finding Gimbal Part for Mavic Mini
aggieswin99
Texas
After a crash my Mavic Mini Gimbal was damaged. I was able to repair the plastics and replace the Gimbal cable. However there is a plastic piece and metal washer piece missing from the front right side (facing the drone). When I look at purchasing a Gimbal housing online it seems everyone is selling the Gimbal with the same part not included. I cannot seem to find the name of the part or where to purchase this piece to fix the Gimbal. Without the part the camera is not balanced and leans to one side. Can anyone advise on what part is missing and where to purchase?
If you have replaced the whole gimbal housing, the serial numbers of the drone to the gimbal no longer match. It will cause your new gimbal To stay tilted or pointing to the left. The missing piece will not help your situation either! Here is a link that also works to calibrate the mini....i am having trouble getting my mini to be seen in the com port driver.... Hopefully you have more luck!
highflyer314
