That's Type C to Type C. No go for a Mini!Not sure if this might be something that helps you?
Type-C to Type-C Cable 65cm
PGYTECH Type-C to Type-C Cable 65cm connects your OSMO Pocket with your mobile phone having Type-C port to control shooting with a bigger screen | With the adaptation of quality electronics included inside, it ensures a stable and safe transmission | The 65cm cable length precisely satisfies...www.pgytech.com
If you want a right angle Lightning side (and you should, to protect the Lightning port from snap off damage!), 25” is the shortest I have found. This one is $14 and is 3 feet and works!I have a MavMount on order for my MA2 and a iPad Mini.
Can anyone tell me the length of the USB "C" to lightning cable I will need?
I would also appreciate the best place to buy it? So far the shortest cable I can find is 3 ft.
Thanks in advance,
Carl
What was wrong with the Amazon one I linked above? It's definitely available and Amazon Prime. The extra loop won't make any difference, since you have to loop both cables anyway, as neither is the ideal 10” length..I plan on calling them in the AM to see if they have a USB “C” to a “LIGHTNING”
connector at that length.
I'm sorry but I continued to look for the shortest cable I could find. It appears I found one, not on Amazon, that is 65cm long. (25.591 inches) I do appreciate your help GadgetGuy.
Thanks in advance,
Carl
MA2 requires a USB-C connector, not mini USB.CAR,
I have been using a cable that I purchased quite a while ago for my Spark and my Enterprise Dual. I am attaching the link to the cable for Amazon, it is 12” long total, it works great for both drones. Hope this helps.
No problem. I ordered both sizes myself, and the 10” longer 36” one is indistinguishable from the 26” one, since both have to be coiled/looped to be shortened, and an extra loop in the coil just blends in. I'd like to avoid the loop entirely, but anything longer than 10” will require looping. The right angle connector is also essential, too, in case the cable snags, and for leaving the cable plugged in, with the tablet already mounted on the RC in a backpack. There is a possibility you can still use the stock cable with the Mini in your MavMount. I can mount my Mini with the stock cable in the PGYTECH mount, but not the full sized iPad, which I prefer to use. Just slide the Mini slightly off center to make it fit.I'm sorry but I continued to look for the shortest cable I could find. It appears I found one, not on Amazon, that is 65cm long. (25.591 inches) I do appreciate your help GadgetGuy.
This is what you want I think...the cable is nice and short and ideal for ipad use...I have ordered one but it hasnt arrived as yet...I def think there is a market for short 90* usb-c to lightning cablesI have a MavMount on order for my MA2 and a iPad Mini.
Thanks in advance,
Carl
He already has the mount, only needs the cable. Your link is for a $75 mount with selection on what cable to include.This is what you want I think...the cable is nice and short and ideal for ipad use...I have ordered one but it hasnt arrived as yet...I def think there is a market for short 90* usb-c to lightning cables
Product Page | LifThor Shop / TDW
www.thorsdroneworld.com
Yes i know that but it had the cable selection as a reference. when you go to the cable page its a bit confusing...at least it was for me.He already has the mount, only needs the cable. Your link is for a $75 mount with selection on what cable to include.
Great effort everyone. I spent most of my day trying to find a right angle one for my iPad to MA2 controller. No dice!
