Hi from Florida
Welcome to the forums - a lot of good info here. So, take a look around and hope you enjoy some of the fine photography and information posted by the members.
Also, if you haven't done so yet, consider getting the AirMap and KittyHawk apps. I also suggest this Visualize it: See FAA UAS Data on a Map
Welcome to the forum! :)
New pilot from Miami, FL. Received a MM2 for Christmas
Here are some things to help you get started with your Mini 2:
  • The current Mini 2 manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mini 2 downloads page.
  • Check out this getting started guide for some tips not found in the Mini 2 manual.
  • This video covers all the basics of the Mini 2.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Thanks for the share! Awesome resources. Already had hooked up to AirMap and Airdata.
Mavichelp is awesome!
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . ?
WELCOME to the forum :)
RichardThiery
