Hi from St. Charles, MO!
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
welcome to Mavic Pilots! :) Enjoy the forum!Thumbswayup
Hello from the Crossroads of America jmlovetto.
Here's a couple of places to start.
Depending on what and how you're flying your aircraft, it may need to be registered with the FAA.
Regardless of what you are flying (or not at this time), you should take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy take.
Good luck and welcome to the Forum. :cool:
Welcome to the forum. Ask your questions, you will find this to be a helpful community. We look forward to your participation and your view of the world.
The only dumb questions, are the ones invited to ride with you all the way to the scene of the crash.
So don’t let them onboard!
This whole forum is about questions and answers. I see there are very smart people here who help us all as we all help each other.
Hi, new to the drone community and I will have questions, sometimes dumb questions...so please bear with me.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
You.ve been given the heads up on the various legal requirements and if you do not do these simple things, you'll learn a lot to begin with…
We love answering questions, it gives us a chance to stretch out legs and brains a bit… But we ask that you try our Search Features first as we have already answered so many, many questions.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Missouri, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
You did not say what if anything you are flying, Let us know and we might be able to hook you up with some great links…
Happy Droning…
Hello from New Mexico (you know, cleaner than the other Mexico).
Welcome from sunny Ft. Myers, Florida! Please reach out if you have questions.
Welcome to the forum! :)
cyskka
