Checking in with my first drone,
Mini 2. Have it already for slightly over a month but still at the beginning of the learning curve.
mavicpilots.com
Since you live in singapore, there are specific laws and rules for you to follow, please check to ensure these are current.
According to the CAAS, flying drones is legal in Singapore, but certain regulations must be strictly followed. Read on for more details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Happy Droning…
