Hi, I'm still struggling and frustrated with camera settings mainly over exposure.....appreciate any help / hints. Have tried many different settings combinations including filters to no avail
WTB post above is good advice.Hi, I'm still struggling and frustrated with camera settings mainly over exposure.....appreciate any help / hints. Have tried many different settings combinations including filters to no avail
Which drone?
Stills or video?
Is it the whole image that is overexposed or just sky?
What mode are you shooting in?
The two most common problems for people who have little experience in photography are;
1. the exposure compensation is set to a positive value. It won’t matter what setting you alter in AV, TV or auto mode the camera will add the exposure compensation value to what it thinks the correct exposure should be.
2. You are trying to use some arbitrary settings in manual mode without considering the resultant EV and or/selecting the correct ND filter value.
So are these the ideal settings ?WTB post above is good advice.
Look for the line of camera data near the top of your screen. It looks like this:
The number under EV is what's important.
Yours is probably set to something more than zero.
You need to dial that back to zero.
There's no "ideal setting" because people shoot different things in different conditions.So are these the ideal settings ?
You might find your ideal settings will be auto with exposure compensation set to 0.So are these the ideal settings ?
Helped what? Lowering your TV to twice frame rate for video? There should be no need for any ND filter for stills unless you are hoping to get blurred motion for artistic effect.Similar problem. Installed an ND8 filter which helped a great deal. I'm considering an ND16 for bright sunny and cloudless days.
An ND filter isn't the solution to the OP's problemSimilar problem. Installed an ND8 filter which helped a great deal. I'm considering an ND16 for bright sunny and cloudless days.
In my case I constantly was dealing with the over exposure "zebra" stripes. The ND filters helped tremendously.An ND filter isn't the solution to the OP's problem
If you've got overexposure problems, the solution is to adjust the exposure properly.In my case I constantly was dealing with the over exposure "zebra" stripes. The ND filters helped tremendously.
Marvic Pro. Both still and video. Whole picture's over expised not just the sky.
