How to find the version of DJI Flyapp? And a Flight Data Center question ;)
Ronny St.
Broechem, Belgium
I will probably overlooked it, but when I open the DJI Flyapp I cannot find the current version installed?
And I also noticed that in the Flight Data Center it continuously says that some flights are not uploaded with numbers going from 2 to over 30, but they all seem to appear in the list given.How can this be explained?
In the meanwhile found that I can retrieve an app version in settings of Android. But I still wonder if it is not given anywhere in the app itself.
Early on in the history of the Fly app, you could see the app version and build number from one of the options off the intro page. It would even show if the app came from Google or manually installed by APK downloaded from DJI. I can't find that anymore.
You can see the app version from the About section of settings under camera view.
I've noticed that Google Play might not show the correct app version of an update if you haven't launched the version of the app previously obtained and installed.
Reactions: Ronny St.
Under Profile - Settings - on the left at bottom you see the version..
Check the screenshot
mini2+
