How to manually sync flights with autosync off on FLY app.
rafare
Brazil
I don't want to use autosync because it automatically deletes the DAT, which, in case of an falilure or a crash I really want to look at these logs. But I still enjoy looking my past flights on airdata, so how do I manually on FLY app, sync the flights with dji server?
Thanks
You need to make a backup of your dat files before enabling sync.
I use OneDrive for online storage and on Android, the OneSync app. It's configured to back up the entire DJI Fly app folder to OneDrive (one-way upload only).
Fly is configured not to sync by default. I get home, run Onesync to back everything up to OneDrive then run Fly and turn on sync. When it's finished, disable sync.
There are also apps that will copy files to an SD card on Android using an OTG adapter.
Yeah, I do the same on iPhone, but the question is, I can't find any way to manually sync the data, the only option I have is to turn autosync just for a brief moment to upload data and then turn it off again. That doesn't make much sense. I thought that there was another way but does not look like it does.
Reactions: Dronernator
Justn go to and click my logs then first tab is uploads then select file
Yeah, but you can link your dji account with the airdata, so it shows there automatically when you sync your flight with the dji account. Then you can see every flight you ever done.
SkyTechDji
