- Joined
- Oct 12, 2016
- Messages
- 28,304
- Reactions
- 31,125
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
The video implores you to land as soon as possible when receiving high wind warning. The mention to check remaining battery level is wise. If, depending on distance from takeoff, battery shows 50% or more, I quickly turn camera straight down to assess if obstacles like trees or building heights are close to altitude of Mavic 2 Pro. If there appears to be room, the left stick is pushed forward to descend until the high wind message goes away. Flight is then continued, usually with no further warnings.
Oops, mental burp. You are correct.Do you mean left stick is pulled back, or do you have the controller set to a different setting than stock?
