Hyperlapse settings
LowCountryFlyer
Does anybody have good recommendations for best practices in using the hyperlapse system on the Mavic 2? I've logged a couple of test flights where I shot some stuff using Hyperlapse and learned a few things, notably, the longer the time between shots, the longer the drone is up for and there are limitations when juggling movie length vs aircraft endurance. It also requires much stiller air to do it properly without the footage looking jittery. Anyone else have suggestions?
Thanks
Thanks
One suggestion that I've read was to focus further away or avoid foreground objects. Close up trees or similar can look jumpy as their motion is closer to the camera and is magnified if there is some movement.
Reactions: LowCountryFlyer
Thanks
twistedpair
