I am a newbi from Alabama
Welcome to the forum! We've all experienced a flameout and crashed (at least most of us) ;). I hope you get your bird back soon. . . enjoy the forum! We are happy to have you!!
Welcome from the Hampton Roads area of Virginia. I am a Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
When I had to return my Mini 2 using the DJI Care Refresh Express Service, I had some issues with my replacement Mini 2. I use an Android Galaxy S2 Tablet, while you are using an IOS Phone, but perhaps the issues might be similar. Your phone might find the original Drone first and try to connect to it using the credentials to the new Drone…
See the following Link is see if the situation might be similar…
This is how I fixed the "Quick Transfer Password Authentication Error" on my DJI Mini 2.
Now onto some more advice that might keep your drone flying more and being returned less…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). Open the front legs, open the back legs of your drone, then remove the Gimbal Cover.
Place the drone down while it finishes its self-test (collecting satellites, etc…).
I would also advise you to use YouTube and watch a lot of the Videos on flying and setting up the Mini 2. When it is too dark, too cold, or too wet, you can "fly it vicariously" through YouTube. Also watch some of the Blooper Drone Videos and learn how not to fly your "New Baby;" also read over the user's manual… the link is below in case you did not get one…
Happy Droning
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching
and stay safe.. 👍
Welcome to Mavic Pilots! :) Enjoy the forum! Thumbswayup
Already crashed it and had to send it in to DJI. They were very efficient and now having trouble connecting my iphone to the RC. I did a support chat yesterday and am working on the issue..
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Reactions: Skywatcher2001
KiKiHUN
