I have an older mavic pro i need 2 know password 4 wifi manuel says its on front arm i do not see anything. Can anyone help please
Its def under battery but why do so you need to connect to it - do you have a controller or are you connecting with mobile device - normal hookup is a cable from wireless device to controller and controller speaks to drone via occusync
the password has nothing to do with flying with the controller it is only for when you want to use your phone or other screen device to fly your drone without the controller but it restricts distance and height and speed of the drone when used it is under the battery attached to the drone
Reactions: RadioFlyerMan
You need to look for a sticker like this. It should be inside the battery compartment.
On my Mavic Pro it is on the Front right arm, if looking from behind the drone and the arm's are unfolded. May also be in the battery compartment.
Now, if you have a Phantom 4 or DJI Spark, the DJI Assistant 2 is the same version. ... device whether it is the latest Mavic 2 or a DJI Goggle, Mavic Pro, Spark, Phantom, ... The DJI Assistant 2 software is not a cellphone app. ..... To find the SSID and password on your Mavic, check on one of the front arms.
fotonews
