Yes, most countries with any sort of airspace authority generally has the VLOS rule and other such.
I'm surprised the US doesn't have a lateral buffer to fly over people, like 30m in Oz, 50m in UK, and not simply to avoid flying directly over people.
You can fly over highways / roads, CASA drone rules state "you must not operate your drone in a way that creates a hazard to another aircraft, person or property", and they have a little diagram with heli, house, car.
Define create a hazard though, and yes one could argue just being in the sky is a hazard.
I feel getting somewhere, ok to overfly, keep altitude, don't loiter, just get over to the landscape you want to film and back with little risk.
Yes, people break the VLOS and other rules ALL the time, often out of sheer ignorance of the rules . . . though you wonder how long one can fly as a newbie, and not see reference to rules at some point, faceache, forums, news etc.
Some don't care at all for the rules, and of course, some try and be responsible and occasionally do something outside the rules before noticing and rectifying (much like correcting if you go over the speed limit in a car by a few km/hr).
Range extenders will extend range / distance of course, but also give better signal in urban, when the rules allow urban flight.
I feel the Titan type range extenders are more likely to assist than parabolic dish things, which can focus (concentrate) signal perhaps, but reduce coverage so make orientation (aim) more important.
Don't have either, but mentally note others experiences.
Flying BVLOS is so (so) easy, and I admit myself, quite exciting in the right environment . . . once used to FPV on device with telemetry, understand LOS and limitations etc of each model drone, you can easily fly safely in regards to flight itself . . . it's just the further away you are, you can't really have that spacial awareness of other (manned) aircraft coming into play, and risks from other such things, birds, transmission lines, etc.
I'm sure CASA will be watching the US FAA outcome with the remote id proposals.
Hopefully, our market here isn't quite big enough to warrant such a thing, we really have minimal problems here with drones and other aircraft / crashes in traffic etc. A handful of minor things.
That said, the US and its market size hasn't really had a bad record either, though a heli or two down is not good.
I try and fly safe all the time, putting thought into every flight beforehand.
Most times this is all good, sometimes I'll see people nearby that have come into an area I'm flying, and have to avoid them.
Usually I keep in reasonable VLOS (strobes) and like to be close, only once have I flown 1 km or so away, that was very remote central WA.
Edit- fixed typo (yes, I'm a bit pedantic, glad edit later has been restored it seems ?)
