So i just bought global drone gd891080 p for the first time in my life. Its a beginners drone and i test fly it on headless mode. It was fun and amazing but the only problem is the app that they asked me to download, cant give any live feed. At first it did but not long after it wouldnt show anymore. I attached a file to see what im talking about. I did connect to the drones wifi. And yet it still dint work.
I own a 2 small drones. beginner drones. total I have had over 3 different types. I have not flown any of them it in a while.
this software looks like my small drone software. if it is, then it works the same way as my small drones, then I think all you have to do, to connect the drone is to the phone or controller Is:
1) turn on the drone...there should be a light somewhere on the drone to let you know that the drone is on...if it is, then it might be flashing (fast), then look at the controller.
2) turn on the controller, there should be a button the the controller, slide it from one side to the other...you should hear a beep, and the drone light should stop flashing...the drone is connected.
now looking at your picture of your controller...the left controller button, is at the bottom. there is a setting on this controller to level it out (bring it to the middle). it is in the setting button..I believe it is called the satellite or maybe even looks like a satellite on the [button]...the drone does not connect to the satellites, but the setting levels out the controllers in the software. now I know I did not ask you if you had a controller or if you are flying the drone from your phone, but all of the small drones fly the same way. if you do not have a controller, then one of the icons [buttons] on the software connects the drone to the phone.
I realize my instructions are still a little unclear, but I hope this can help you out.
one last thing....you will have to trim the drone, once you get it in the air..to come down the drone [moving all over the place while hovering...i.e. [forward, backwards, left, right]
these instructions or the sad thing about this...you will have to go thru this process each time that you change the batteries or power the drone or controller off and on.
