Should I keep it in AUTO?, 50, 60.... OFF? Could the Pros give me thier view on the Anti Flicker choices?
Actually your reply meant a lot. Because I always knew overseas used 50hz and USA used 60 hz but I had know idea how it was involved with photographs and videos. So keeping it in Auto makes a lot of sense providing Auto works and functions properly.Are you doing flights with artificial lighting? I am not an expert! But those settings seem to be designed for artificial lighting. 50hz overseas, 60hz usa would be the setting of the lights.
this probably didnt help you at all. so sorry!
Correct, only for video. If you video mains lighting in the UK, use 50Hz, in USA 60Hz.(yes, I know other countries have similar), that is because flickering can occur in the video due to harmonics of mains frequency. These settings are designed to filter out any potential flickering.If I understand it correctly, it will only affect video recordings, not still.
