My understanding is that log files (txt) can be retrieved 2 ways:
From an SD card inserted into the drone
From the Smart Controller/app
I am working with a custom app that uses the Mobile SDK (Android) and don’t fly with an SD card. Is there a way that I can still access the TXT files? It’s worth noting that I fly using a Smart Controller.
Alternatively to interrogating the TXT files I can use the SDK to receive/log the info that I require, however some elements that are in the TXT files appear to be missing from the SDK (I.e. ‘is motor blocked’ and ‘motor fail reason’). On top of this it would be useful to see the current draw per motor which appears to be available via the Onboard SDK.
Does anyone know if there is a way to achieve what I’m looking for?
Thanks!
Thanks!
