- Joined
- Nov 9, 2017
- Messages
- 364
- Reactions
- 99
ok, after 2 days of pulling my hair out this is what I’ve found.
I have been experiencing disconnects from the RC, while flying, or even just powered up sitting and what I have found is, it is very repeatable almost set your watch to, as a matter of fact I used a stop watch at 4 minutes 13 seconds the RC will disconnect for 1 second then reconnect but this is enough to initiate a RTH
Because that what I have it set at. It does not matter on the distance it can be 5 feet or 1500 feet away
It indicates (weak signal readust antenna)reboots and is good for 4 minutes 13 seconds then repeats I had tried different versions of the app (IOS) using on iPad, and no difference I have reinstalled software on the aircraft and no change. I’m still thinking it’s a software issue,but will not rule out a hardware issue yet either.
Has anybody ever had this? I have refresh so maybe it’s time. I have about 30 hours of flying on the bird
And over 100 flight miles, never crashed
