Sounds like the equipment was causing GPS interference.
Actually any indoor location, whether it has equipment or not will attenuate or completely block GPS, even an empty warehouse. Therefore it might not have had anything to do with the lasers.
If you are flying low enough, the vision position sensor can be used to stabilize flight. If VPS is not effective such as too high, not enough light or ground has no pattern, then AC will go into ATTI mode.
I suppose the lasers could blind the sensors, but then they would have you wear eye protection, and you'd notice the light through the main camera.
