iPad Mini cable
Ironace
Virginia
I have an iPad mini on the way, can I use the stock lightning cable or do I need to buy a longer one? If I need a longer one which one do you suggest?
Thanks in advance for your help.
I'd just add that it depends on how you're mounting the iPad mini on the controller - if it's the PGYTech bracket, you'll need a longer cable. I use a Hanatora cable from Amazon, works great.
Reactions: GadgetGuy
I am going to use this mount so maybe I will order the cable you suggest just in case:
Hope you got a Mini 4 or 5, DJI Fly is a cpu hog.
Thank you Sir!! I searched but amazon did not pull that one up... ordered two
For whatever reason, Amazon *sucks* at locating specific USB cables by connector type.
Reactions: Ironace
The description of the tablet mount you linked explicitly states does not fit the Mavic Air 2.
Lekufee Lightweight Aluminum Alloy Foldable Tablet Holder Mount for Mavic Mini/Mavic 2 Pro/Mavic 2 Zoom/Mavic Pro Platinum/Mavic Air/DJI Spark Remote Controller(not fit Mavic air 2)
I'm not sure why... I have it and have used my ipad pro with it just fine while flying my MA2.... I will post photos when I am off of work.
Opus3
