The dimensions for max device size are in the manual.Planning on getting an iPhone 12 pro max. Will this fit on the controller? I do want a bigger screen when flying my drone.
Many of the controllers can accomodate the iPad Mini's without an adapter.
MA2 317" data-source="post: 1134060" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Seriously? Bummer. Thanks for the correction. Do you think the Mini2's controller is the same as the MA2?
Exactly, though their are subtle differences.. And while they look virtually identical, and are both OccuSync 2, they are reportedly not interchangeable..Seriously? Bummer. Thanks for the correction. Do you think the Mini2's controller is the same as the MA2?
Interesting, course its all new and I've seen postings that say they are not, but it stands to reason that with appropriate firmware, they would be compatible.Not according to DJI and what I have read, check the Mavic Mini 2 FAQ, 3rd up from bottom of list: DJI Mini 2 - FAQ - DJI
"Yes. Update both the remote controller and the aircraft, and you can use normally after successfully linking the devices."
They both carry the same DJI Part number as well
How did it go with your iPhone 12 Pro Max and the MA2 controller? I’ve got the MA2, and it’s a tight fit with my iPhone 7. Would like to get first hand experience before I upgrade. Thank you!I Pre-Order an iPhone 12 Pro Max and is arriving next Friday. I can test if fits well but i am pretty sure it will. The Galaxy Note S20 5G Ultra is bigger and fits.
Fits just fine.Planning on getting an iPhone 12 pro max. Will this fit on the controller? I do want a bigger screen when flying my drone.
