I have replaced both propellers on right rear motor after mini was coming in for a landing. The drone just dropped about 6 ft above ground when it just dropped, hit the ground , bounced back up and then fell back onto ground. I noticed after looking at the flight data it said max power load reached, decrease altitude and fly with caution , land immediately. Code 30168. I also had a low battery voltage fly with caution code 110011. Does this drone just crash down when the voltage gets too low? It was sitting at 19% left. The temperature was around 2 degrees Celsius or around 36 degrees Fahrenheit. With the bouncing on the ground it chipped one of these props. Is it safe to fly it without locktite on the screws?
