Is the a way to get pixel ratingfkr this drone
Kosmo98
Minnesota
I need to get 1 or 2 pixel per inch with this drone but I have no idea how high I can fly to achieve this.
Use DroneDeploy for your flight planning and it will calculate and show you.
Even if you don't want to use DD, download their app and play around with it to set up a trial missions.
No need to do any flying, just connect the drone and it show you what you are looking for.
Adjust the height and see how that changes the resolution.
Depends solely on the size of yr sensor & the FOV of yr lens. if yr drone is a M2P with 5472 pixel sensor & FOV 77 deg & u want 2 pixels per inch then the height in inches is approx. 2736/(2xTan(38.5))=1719”=143 ft
Drone deploy doesn't work with this
I have the mavic 2 enterprise advanced
Lucky you! Thanks for clarifying exactly which Mavic 2 Enterprise drone you own. You have the only one it doesn't work with! Maybe borrow one it does work with to get the information you seek?
rlafica
