The threads on the controller for the Mavic Air 2 are machine thread 8-32. (size 8, 32 threads per inch)
To increase my joystick sensitivity and get rid of the very big jerkiness problem in trying to control the drone movements, I used 2" 8-32 machine bolts with 6 nuts on each and put a rubber cap on each one.
The nuts can be moved up and down the bolt as a group and so can be positioned where they work best depending on the sensitivity required. Raise them to increase sensitivity and decrease to lower it. (distance from the controller)
If you have really big fingers or wear gloves in colder weather then simply add more nuts.
