So I was flying my drone across the lake 500 feet away and it nosedived for some strange reason now I need to figure out how to pinpoint it so I can try and retrieve it any help would be greatly appreciated I'm sitting in my boat right now
Go to DJI Flight Log Viewer | Phantom HelpSo I was flying my drone across the lake 500 feet away and it nosedived for some strange reason now I need to figure out how to pinpoint it so I can try and retrieve it any help would be greatly appreciated I'm sitting in my boat right now
Do you have the actual GPS location for the crash location?I have the last GPS I have the last GPS coordinates I just need to know how to locate that
A GPS app on your phone would be the next best option.I have the last splash point... no hand held GPS
Viewing a point on Google Earth probably isn't much help to pinpoint a spot 500 feet out on a lake.Good luck
I sunk and found my drone. As I recall GO4 App using find my drone feature provided both the last known spot and where I currently was. I just zoomed in and tried to keep my blue dot at last known location. It was amazingly accurate.Viewing a point on Google Earth probably isn't much help to pinpoint a spot 500 feet out on a lake.
He needs a way to tell when his boat is in the right position.
As posts #6 and #10 were trying to point out, the app can only show the last point where it had contact with the drone.I sunk and found my drone. As I recall GO4 App using find my drone feature provided both the last known spot and where I currently was. I just zoomed in and tried to keep my blue dot at last known location. It was amazingly accurate.
If you post flight data, someone might be able to see if it gives any clues relating to the incident or at least eliminate some common causes.We resume the search tomorrow.... party started... no searches under the cloud of mad dog 2020
All I need is today’s mathematics to close the threadIf you post flight data, someone might be able to see if it gives any clues relating to the incident or at least eliminate some common causes.
(as well as confirm the crash location)
