That's the FAA facilities map for controlled airspace. Each square has an allowed altitude ceiling. You can't request clearance above said ceiling in LAANC, not even under 107. 107 can ask to go above it manually through DroneZone. Hobbyists cannot get an exception.
The facilities map only has 2 colors: red means LAANC not available for that location, green it is available.
