Version 9.3
Welcome to LAANC 2.0.
In this update, we’ve implemented LAANC 2.0 which means it has all the latest FAA data sources, rules and requirements packaged into one seamless workflow. We’ve worked long and hard to make requesting and using a LAANC authorization easier than ever. You can also now view your authorization directly within our Dynamic Airspace™ view. For more complex flights and missions, you can also request authorizations in areas covering multiple airports.
Kittyhawk enables thousands of LAANC authorizations every month so we’re always learning from edge cases and new user needs. This is the LAANC experience that we’ve always wanted to build and we’re committed to continually perfecting it as our national airspace becomes home to more drone flights and advanced operations.
Aloft (formerly Kittyhawk)
Aloft (formerly Kittlyawk), is the #1 FAA-approved LAANC provider and the industry-leading solution for drone ops, fleet management, and airspace UTM solutions. We power the largest network of recreational, commercial, and government drone flights across our suite of applications. This is our...
apps.apple.com
