Litchi & Google Earth
QuadKid
Daytona Beach FL
Recently pre-planned a mission using the Hub and exported as KML to Google Earth with a serious discrepancy, not sure which data to trust at this point, Have emailed Litchi for response. Anyone experience this as well.
Typical POI mission
Image 1 ( planned mission in Hub)
Image 1 exported to Google Earth as KML (Notice severe offset)
Adjusted Mission in Hub to compensate for offset in KML
Adjusted Mission Hub data exported to Google Earth as KML
Reactions: ksmusa
Wow, unbelievable. I was getting on to ask the same question.
Litchi:
Google earth:
As an aside, is it possible to turn off the lines going down to the ground? My mission is multi-level and I'd like to see just the flight path.
Toni
Litchi:
Google earth:
Toni
You can also d/load your mission as a CSV file and fly it in virtual reality within Google Earth, here is the link to it from another thread. If something is askew the virtual flight will not fly properly.
Virtual Litchi Mission
I'm seeing a discrepancy between Litchi and mission hub. Not sure which one is right. Quadkid your csv tut is fantastic. Thanks very much. Unfortunately its not of as much use to me in China as google has 3d data on only a few buildings. The vertical image below is from mission hub. the second is from Litchi on my ipad. Any insights would be much appreciated.
testtest
