litchi , mavic strange behaviour
majeszczak
Is it just my mavic that behaves strangely and aggressively during the planned mission? flying from point to point rapidly brakes and accelerates, the flight does not run smoothly. and does not want to land, despite the correct mission settings. getting lower,. asks whether to land and nothing. Just hover
Do you have demonstrably higher speeds set from one waypoint to another?
Are you using curved radius turns or hard angles?
Are the speeds much different from waypoint to waypoint?
Link me the mission on the mission hub. I want to take a look at it.
Do you have demonstrably higher speeds set from one waypoint to another? - NO
Are you using curved radius turns or hard angles? - NO
Are the speeds much different from waypoint to waypoint? - NO the same
Link me the mission on the mission hub. I want to take a look at it. - ok, i'll i need to record it one more time
i is heppenig in normal flight ,,.. normal speed, with no action
If you have the mission on the mission hub you shouldn't need to record anything, just provide the share or the exported csv file of the mission and post here so we can import it and see the mission parameters.
bertmag
