Has anyone else experienced this?
Today tried to do an orbit around a park. once everything was programmed in, I set the drone off to do the orbit. After ascending to the required height and moving north, I saw that the drone was getting closer to some trees than intended (about 100 metres away). My orbit was set to about 20 metres diameter about 50 metres away 21 metres height. No problem I thought and moved both controller sticks down and to centre to pause the flight. I also tried ascending and flying in reverse. Nothing happened and the drone continued to move towards the trees looking for its start point. More frantic control stick pushing had no effect. After a few more seconds, crash, bang wallop and the drone ploughed through the very top canopy of a few leaves on a tree that was about 30cm higher than my flight level.
The video was still streaming and I saw lots of tumbling and finally static leaves. I started walking towards the spot and a dog walking lady advised me she had seen the drone crash to the ground very close to where find my drone had it located. Long story short, brand new replacement drone with 13 minutes on the clock has a broken gimbal.
I know where I went wrong with the orbit planning (my start point was not accurate enough), but I believe the control sticks should have paused the mission and they didn't. Analysis of the flight on google earth shows the drone doing what was planned, but no change to the flight on control stick movement when I realised what was happening (a point about 50-60 metres from the trees). Just to clarify, I had a clear line of sight between me and the drone and could see the disaster unfolding before my eyes. Also, I realise that the Litchi mini app is a Beta phase app but I have had a similar crash a few months ago when Litchi did something unexpected.
On yet another occasion, I narrowly avoided hitting the side of a building during a spiral orbit when the drones spiral orbit grew larger and larger at a very impressive speed until it was about 60 metres in diameter and out of control. On that occasion pressing the RTH stopped the flight. This time, that did not work.
Anyone experienced problems with pausing any type of autopilot manoeuvres or missions in Litchi.
I like litchi and am on the Beta test programme, but sense that it can do things that throw curved balls at you at the most dangerous moments.
