Litchi - Stop/Hover at Waypoint for more than 32 seconds
adamm
Perth
Hi All
I have a survey I need to do where I need to take the Mavic 2 up to the same exact location everyday and take several minute of footage of the one location. I need the exact same GPS, Height and Camera Angle/Pitch etc.
I can do this with Litchi Waypoints and using a POI, however I can only hover at the waypoint for maximum of 32 seconds. (Not several minutes or longer). I see no reason why the hover should be limited to 32 seconds?
Doe anyone know a workaround or another App?
Cheers
Adam
Perth, Australia
Create the mission and take the point you need to hover as end of mission. Then choose in the settings under the option "final action" the "none". The drone will stay at the position untill either you command it to moev on, or untill the RTH is triggered by low battery.
If you have more points to hover, make seperate missions with the same option.
You can repeat the mission(s) as often as you need to.
Your welcome.
da4o98
