long range antennas for mavic pro platinum ?
imavicpilots
Israel
Hi, i know the MPP has a very decent range of about 7 km maximum.
In reality, droning over a sloped terrain with lots of trees cause quite somme connectivity loss, well under the 1 km range.
Are there any 'premium' antennas compatible with MPP that'd have a stronger signal and/or longer range?
I’m sure there will be others with a different opinion but the two that seem to be regarded as the “ultra premium” models are the Titan Switch
And the AlienTech Pro
The Titan Switch comes with different antenna options depending on your environment and how focused you want to be on pointing directly at the bird.
The AlienTech only has one antenna set that is very directional so it will broadcast further than the Titan but you have to point the remote within 45 degrees on the drone.
Dang, ( Mod Removed Langage)of a mod!
What's going on with the magnetic interference?
Bradford
