DiscoverSpain
First, I want to clarify that I am not judging you, but rather offering a different perspective from what other pilots may have already provided.
I am a European pilot, and while I may not be familiar with your country’s FAA and local regulations, I can provide feedback on your flight and the discussions you had with the park managers, drawing from European standard, specifically in Spain, where I usually fly and am familiar with all the regulations.
In Spain, for a flight like yours using a Mavic 3, you would be required to (I've omitted certain details to avoid making the post too lengthy):
Would I have flown in your situation?
No, I wouldn’t have. I think you’re underestimating the possibility of a drone malfunction, whether it’s a motor, arm, propeller failure, drone stops responding to commands from the controller, ...etc. which could cause it to fall almost uncontrollably. You might argue that the odds are low, but I’ve experienced this firsthand. My drone likely lost part of a propeller, though I’ll never know for sure. When it crashed, it destroyed several propellers, and due to where it fell, I couldn’t find all the pieces. Fortunately, the incident happened in an empty field, 20 meters directly above me.
When weighing the benefits of capturing the images versus the the low, but not impossible risk of this happening, of your drone crashing into a crowded park attraction at 100 km/h, my answer is clear: No
By the way, I really liked your video.
- Approved Parachute Device: The drone must be equipped with an approved safety device, such as a parachute system, that activates in case of sudden acceleration, or can be manually deployed. This is important because your assumption that the drone would fall straight down onto trees or rooftops in case of failure is incorrect.
- Flight Plan Submission: You would need to submit a flight plan, including:
- Flight schedule(s)
- Planned flight trajectory
- Designated normal and emergency landing zones
- Other relevant details
- Risk analysis and risk mitigation plan
- Drone maintenance plan and register
