My first
M2P had a defective lens with large fuzzy areas and it was impossible to get good focus across the whole frame. About 30-40% of the image was slightly out of focus.
The second unit had the
exact same focus problems! Just in different areas of the frame.
The third unit was finally much better. It too has a small focus issue at the right edge of the frame but it's probably less than 10% of the image, the rest is ok. Compared to the other units I can live with it.
So I think the discussion about
M2P sharpness is a bit more complex than many people realize...
- Less digital sharpness applied than in previous models (not much of an actual problem).
- Relatively heavy lens correction softens the image, especially at the edges of photos. Even in RAW photos, if you use popular programs like PS/Lightroom that applies lens correction automatically in the background.
- Full FOV video uses a subpar sensor readout and is not as sharp as it could/should be.
- Diffraction softens the image more than people expect at "normal" higher aperture numbers.
- Crude autofocus is often not 100% spot on.
- A lot of M2Ps with defective lenses floating around.
