I’ve had an odd issue with a Mavic Pro 2 following firmware .510 upgrade on the aircraft and controller. On launch the aircraft hovered normally but there was no control of the gimbal from the controller. The camera image was unstable. When powered down the gimbal can be moved freely so nothing sticking.
Tried again today at a different location and exactly the same issue. Maximum height was 30-metres.
In both cases the gimbal did its usual corner to corner calibration on startup without issue so the gimbal is operating.
Later today I tried again and... it just worked normally.
Anyone else experienced this?
