Hiya i was flying my drone and was trying to get it home to me but the wind was taking it further away off my flight log could someone work out were about it would roughly land with wind speed and also how high i was flying it ect
How do i get the flight dataWelcome to the forum, bit of a sad intro, but . . .
Go here . . .
Mavic Flight Log Retrieval and Analysis Guide
With the introduction of the Mavic Mini there has been a noticeable uptick in the number of posts requesting help with lost or crashed aircraft. While there is plenty of help and advice available on this forum, and detailed guidance and options on several other websites, I thought that perhaps a...mavicpilots.com
Follow instructions to retrieve TXT log nad if there the DAT.
Post links to the Phantom Help page report, or Airdata . . . attach DAT if you can retrieve it.
Post this up in a new thread in the Mavic Crash & Flyaway Assistance section of the forum here . . .
mavicpilots.com
If you don't go through the whole process in the instructions I posted on your other thread, just posting the .txt file will do.How do i get the flight data
its sure was im trying to do thatwelcome to the forum,would i be right in thinking it was a MM you were flying ,you will need to post you data files for someone to help you
If you can find and post your .txt file, I can analyse it in a couple of minutes.its sure was im trying to do that
The link I gave you has instructions that show you how to find the file.
It has a file name like this: DJIFlightRecord_2020-04-12_[17-50-16].txt
Almost ... can you post it without zipping itis this the right file use need?
I can't get the zip file to open
No .. are you zipping the files?does this one work
I have just posted another one it wont let me open it also but I cant compare it to anything else they all have zip when I click html ect the files then go for me not to pick upAlmost ... can you post it without zipping it
I have just posted another one it wont let me open it also but I cant compare it to anything else they all have zip when I click html ect the files then go for me not to pick upNo .. are you zipping the files?
The file that's needed is a .txt file ... not a zipped text file.
I'm not sure what the issue is, but if we wan't get past it to see the .txt file .... .I have just posted another one it wont let me open it also but I cant compare it to anything else they all have zip when I click html ect the files then go for me not to pick up
