Lost Mavic on Isle of skye -please help.
Jambo83
Uk
Hello, I was flying my Mavic mini up at the old man of storr and it disappeared. I flew it around the back, my phone stopped picking the Mavic signal up and I never heard the motor. 7 hours of searching, still no luck and find my drone and using the flashing/beeping feature never worked. The question I would like to ask is, if you look at the flight log, the drones course ends far from the storr, I would just like to know; because the path map stops does that mean that's where the drone came down or could it have kept flying but no longer recording the flight path? I have attached a link for all the data. I am convinced it didnt crash into the old man of storr and that it fell out of the sky.
Thank you
I believe your RTH height was 108m (above the takeoff point) and that when you lost signal you were around 120m above the takeoff point. If correct then I think the drone would return at that height of approximately 120m above the take off point and along the red line drawn on the attached.
At that height and on that path would it hit the Old Man of Storr?
Lets hope I got that correct, lol
The chart and menu thing come from running the .txt flight log from Airdata (and presumably your phone) through a piece of free software called CsvView
I believe your RTH height was 108m (above the takeoff point) and that when you lost signal you were around 120m above the takeoff point. If correct then the drone would return at that height of approximately 120m above the take off point and along the red line drawn on the attached.
Thanks for getting back to me. I'm not an expert on drones lol. Why would the yellow line stop where it is? I don't think it would've hit that side, especially with the camera shot I have of it lying on the ground looking at a cliff that wouldn't have been seen if it crashed there
Reactions: ven
Sorry I should have provided the following link
DJI Flight Log Viewer - PhantomHelp.com
it's ineractive, drag the various buttons through their movement ranges
You lost the signal at the end of the yellow line after which the controller recieved no more data from the drone.
Please bear in mind that this is my first attempt at prediction etc. so all that I have written NEEDS to be confirmed by one of the Gurus
Reactions: Old Timer
You seem to have had the failsafe (loss of signal) response set to RTH.
If I am correct and it did lose signal through being behind the OMOS and if the rock face is in the return flight path then I think the only way you could have avoided the crash was to (before the loss of signal/connection) shove the maximum ceiling well up over 400ft, enough to clear the OMOS, and set the RTH height just slightly below that ceiling.
You can change the maximum ceiling and RTH height whilst in flight ( but at a guess not whilst actually RTH'ing).
Once you had cleared the OMOS you could have reduced the Mini's height etc etc
Yes, this was most probably a too low set RTH height & lacking knowledge both regarding to how the failsafe functionality works & how severe the RC signal degrades by putting a big rock in between the RC & AC.
The log & the recording of the flight path ends immediately when the RC/AC connection is lost ... that's why the yellow Airdata path stops midair. With a lost connection the Mini will hover & initiate the failsafe action which was RTH after 11sec. If above the RTH height, which it was, the AC will go home at present height which was 119.8m.
Now, the GE altitudes isn't pin accurate but the height difference between the HP and bare ground up there is somewhat 58m ... then adding the rock height to that which says like 50m (quick Google search) for the old man of storr. That make 108m in total.
With all the uncertainty regarding the heights, those 108m is dangerous close to the AC height when the connection was lost. I would start the search near the cliff wall & walk towards the point where the signal was lost, paying extra attention to bushes & small trees along that route. GPS positions in the pic below.
Reactions: Prismatic
Thank you for your help. So do you think it 100% hit the rock?
Well, I wasn't there when it all happened ... but by knowing what happens when the RC lose connection to a AC with the failsafe set to RTH, operated in wind speeds below what a Mini can handle & a RTH flight path blocked by a huge rock on the same RTH height ... then let's say 98% ;)
If you look on Bing maps for the Old Man of Storr you can switch on or to an OS map with 10m contour lines.
If you can work out the positions of your home point and loss of signal points on that map you can then plot the RTH course on that OS map and see if it is above all the contour lines it crosses.
I lost and found my Mini recently, and in addition to the valuable help of members of this forum, I also got the video off my phone and watched the last few seconds for reference. Your phone should have a low-res video of the flight, if you were filming. Seeing what your camera saw last helped me find mine, it might help you.
Bahamaboy242
