Hey Jay, I've tried a few different brands I found THESE are most like the DJI brand and are a bit cheaper. They were well balanced and just as quiet as my DJI branded ones.Hey guys. Looking for recommendations on the best propellers i can get preferably low noise okes for my mavic pro. Or should i just buy the dji low noise ones they sell? Thanks in advance
Jay
Use Mavic 2 props
You have experienced the gimbal shake that 'some' Mavic Pro's get when the 'quiet' MPP prop's are put on them. This can be cured with some 'gain' adjustment - but I'd recommend the Master Airscrew prop's over using the DJI quiet blades ... The following video is a bit long-winded, BUT - explains 'fully' what's going on with the MPP prop's on a MP ...I have tried MP Platinum low noise props but found a really bad resonance in hover. So much so I could see the camera visually vibrating. Slightly lower prop speed at hover and only a slight drop in discernable noise. I`ve returned to using the standard props, no more resonance or extra hard work for camera and gimbal.
