- Joined
- Oct 16, 2016
- Messages
- 35
- Reactions
- 11
- Age
- 65
As mentioned in an earlier post, I was just going to get a M2ED when I came across this solution at:
VuIR Boson - Turnkey Thermal Vision System for DJI Mavic 2/Mavic 1/Mavic Air | suas
VuIR Boson - Turnkey Thermal Vision System for DJI Mavic 2/Mavic 1/Mavic Air, SKU: VB0011
he complete mounting system with:
So the question is, should I go for the M2ED @ $2,949.00 with a 160×120 Sensor Resolution or the SUAS option @ $2,499.00 with 320x256 Resolution ???
My application is Night flying to locate raiding elephants within a 1 Km distance.
With the M2ED I have a Factory set solution and a Gimbal for stabilisation but only 160×120 res Thermal Cam
With the SUAS option I have a retrofit solution on my own MA with no Gimbal but a 320x256 res Thermal Cam
Which to go for, please advise.
Thank you.
- ONE adapter to be attached to the top of the Mavic 2, Mavic 1 or Mavic Air
- Onboard DVR for recording
- Onboard Video transmitter (5.8ghz)
- Boson camera mount with Adjustable tilt angle
- 1 Micro SD card for recording (8GB)
- Special VPC module
- 1 VuIR Battery for operation
- 1 VuIR Battery Charger
- USB cable for Boson
- Ground Thermal Monitor (Black Pearl Monitor)
- 5 Extra VuIR batteries
- FLIR Boson 320 Camera with 13.8 mm Lens
Thank you.
