M2P Gimbal Screws
  • Thread starter Thread starter Deleted member 96190
  • Start date Start date
D
Guest
In need of 4 M2P gimbal screws for a camera swap. I have the body and gimbal, just missing the 4 screws to complete the job. Anyone have any they are willing to part with???
If you are truly doing a swap, you can use the 4 screws on the camera you are replacing. Otherwise, they are the same as the two screws holding the cover on, which you remove to get to the gimbal. I am told Home Depot can match them. If I remember correctly, they are 1.5mm
Thanks. I had a zoom gimbal and purchased a separate M2P body so I do not have the 4 required screws to mount it. I have a Menards down the road. I will have to see if they carry micro 1.5mm to match.
PFCKW
