Hi fellow Pilots,
I just crashed my Mavic 2 Zoom, flew directly into a roof, 100% pilot error.
I didn't purchased DJI care refresh, i know now that it was a great mistake !
Well it ended up with a broken gimbal (which i never found again :-( ... ), a cracked middle body, a rear right arm bracket and front cover to need replacement.
It got a scratch on the very middle of the bottom infrared sensor which i assume is no big deal.
Some minor scratches on the left front vision sensor are a bit concerning.
Right after the crash, i hovered the mavic for a few minutes and seemed to fly ok.
Then i got home, and teared it down for further investigation and and everything seemed ok except a few dings (less than a few tenth of millimeters ) on the metallic cooler on the main board.
I ordered parts and a new gimbal to fix it.
Here is the real problem : now it won't take off, i got multiples errors : no gps, no imu, no internal storage access, and no vision sensing.
I just checked the flat cable between the main board and and gps module ,as all the default system are on the gps module, connection and flat cable seems ok.
Can someone help me ?
Thanks !!!
Thanks !!!
