Got they new MA2 charging batterys currentley. Update firmware/software. Need to set up DJI FLY options soon. Does the MA2 have to be turned on to setup[ controller options?
**** just finish getting the MA2 and controller sorted out. After initial updates over WIFI and tablet it finished setup, so I shut it down finished charging batterys. Turned everthing back on and **** tablet froze wouldnt connect. Did a restart and it started dowloading sofware a second time so I waited for it to finish, **** Chinese writing came up? So I was about to give up when I remember how I had to update the Walkera QR X350, directly to my PC, so pulled out the MA2 cable and dowloaded again, everything is now working I HOPE. Will take it out tomorrow for short flight if everything connects. Found this on DJI website: If the aircraft update fails several times or the remote controller cannot link to the aircraft, then it is possible that the remote controller firmware version and aircraft firmware version are not matched. In this case, it is recommended that users use DJI Assistant 2 for Mavic on the computer to update the remote controller and aircraft separately to the latest version.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
