Every time I go to use the MA2, I have to go into the settings and set it to charge phone. Am I missing something when I make a setting adjustment? It doesn't seem to be remembering.
Because at -7C the phone's battery dies pretty quick
Same problem here. I need to turn on phone-charging from the app every time too, I don’t think you’re doing anything wrong. I can start flying with 100% phone battery and my phone will be close to dead before I’ve gone through my 3 dji batteries.. yes my phone needs to be ungraded soon ?Every time I go to use the MA2, I have to go into the settings and set it to charge phone. Am I missing something when I make a setting adjustment? It doesn't seem to be remembering.
Since you did not mention model or age, assuming it's an older model, eventually those batteries need to be replaced. You have to be careful to find a authorized repair place, otherwise you could have other issues when you get it back, which is probably cheaper then replacing the iPhone..I also use an iphone and I have to activate phone charging every time I need it.
Ken, if its an iPhone 10, and your getting significant battery drain during flights, that seems to me to be a battery issue in that iPhone, course its hard to know for sure. If your using it day to day just for the usual calls, email, texting, etc... Does the battery last all day or are you at really low levels at the end of the day even under average use during the day when not trying to use it to Fly?It's a MA2 bought new middle of last year. 120 flights alternating 2 batteries. The phone is an Iphone10.
Sounds like a bit of confusion, not sure what to do if the setting is not being retained between flights other than to add it to a list of things to check before you fly, perhaps a future release of Fly will resolve that issue..Guys, there seems to be a bit of confusion here.
I am having no problems with my drone or phone's performance. I merely stated that I also have to manually select phone charging from the transmitter if I want it when I fly. in other words the phone charging setting is not "held".
This is the way I think it should work. I don't want the phone to chow up the transmitter's battery power every time I fly - only when i have forgotten to charge the phone before I fly.
