Does it have to be in the air to access this information ? Or can it be on the ground ? Thanks for the reply tho
Or do i have to hold it down or swipe it ? Im sure mine just goes from camera to video mode without all them options .
MA2 317" data-source="post: 1146048" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Yep it works.......must have been me being an idiotI took the screenshot while it was powered up and sitting on the floor inside the house.
I use the button on the remote to switch between camera and video mode. I then tap the icon on the screen to bring up the options. You can scroll up / down in the menu for selections.
You might check to make sure the controller is in normal mode. Maybe the options are not there if it is Sport Mode? ?
MA2 317" data-source="post: 1146048" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Yep it worked......must have been me being an idiot, thznks for that ?I took the screenshot while it was powered up and sitting on the floor inside the house.
Yes i was...but when i checked it again it worked, i used the button on the controller 1st before i pressed the button above the shutter and hey presto it worked. Richyou were probably pressing the button above the shutter button, that switches from photo to video...
