MA2 startup anomaly
dobro2
western Pa
If the remote controller mode switch is in the Tripod mode, when the controller and drone is powered up, everything looks correct. The C mode is indicated and when looking at the Safety screen, Obstacle Avoidance has both options lit, Bypass and Brake. If you select the Bypass feature and take off for a flight, it seems that the flight mode is really in the Normal mode and sideways movement isn’t allowed. If you try and adjust the gimbal, in the Cine section of the Advanced gimbal settings, it has no effect. If you switch the mode selector switch from Tripod to Normal or Sport mode and back to Tripod, it really changes to C mode and you can adjust the gimbal in the C mode . Now when you look at Obstacle Avoidance screen, Bypass is no longer an option ? .. only Brake! Speed, response, and performance are as they should be in the Tripod mode.
I'm using Ipad 10.2 8th gen, Fly App ver. 1.4.3 and the latest firmware updates on the drone
Any help will be greatly appreciated,
thanks in advance
Yes , the Normal mode always resets itself, so if think your in sport mode because that is what it is set on when you powered off your really in normal mode,
Phantomrain.org
Gear to fly your AIR 2 in the Rain and Land on the Water.
ElleryDavis
