There’s a new safety feature that basically deactivate left/right movements on the right stick, you probably turned it on.I was going to land with 4 min. Left on battery and when I tried to go left or right nothing worked. Right stick only would go forward and backwards. Does anyone know why this would happen??
Ok I don’t know about that. I’ll check the settings and see thanksThere’s a new safety feature that basically deactivate left/right movements on the right stick, you probably turned it on.
Yea I found mine turned on, I didn’t even know it was there in the settings ?After the latest update, some people have reported that it defaults to that setting. Better check mine.
Have you also checked your RTH status?. Mine had defaulted to Land.Yea I found mine turned on, I didn’t even know it was there in the settings ?
No I haven’t but I’ll check it right now thanksHave you also checked your RTH status?. Mine had defaulted to Land.
I ran into the same issue last night. Ifound it only shut off the right and left movement when in normal mode. I still had R&L when Iwent to Tripod or Sport modes.I was going to land with 4 min. Left on battery and when I tried to go left or right nothing worked. Right stick only would go forward and backwards. Does anyone know why this would happen??
Happened to me yesterday. Not knowing what else to do (at the time), I <arbitrarily> switched from "normal" to "tripod" and back again and that somehow corrected it. I can think of no POSSIBLE USE for intentionally disabling right / left movement... You?I was going to land with 4 min. Left on battery and when I tried to go left or right nothing worked. Right stick only would go forward and backwards. Does anyone know why this would happen??
ya...that's what I did.It doesn't help that the button for turning the "no left/right" is directly above the "Take-Off" button at the left side of the screen.
