Staples Office Supplies can make 3 foot X 2 foot prints. (Or approximately 915 x 610 mm). Depending on where you are it costs in the $20 - $30 dollar range. I've been planning on getting a print like this done of a 48 Megapixel super rez photo for a while. I finally got around to it yesterday.
I took a super rez shot of my property from the air. It came out the normal 8000 x 6000 pixels.
8000 x 6000 doesn't quite fit the 3:2 aspect ratio so I cropped a bit off the bottom to make sure the margins were equal on all sides. This turned out to be 8000 x 5333 pixels which is 42 Megapixels. Printing at this resolution results in an image with 222 pixels per inch both horizontally and vertically.
I was impressed with the quality. Normally, poster sized images created with 4 or 5 Megapixel images are meant to be viewed from a distance. But the 42 Megapixel image kept the resolution high. Not only can I view it from a foot away, but I can use a magnifying glass to pick up even more detail. In the photo below I put my M2 in the corner of the shot to show the scale...
