the only reason i saw it was red on a RTH was because i made a point of checking mine after i had seen this thread, it was green as usual until i pressed RTH, and i noticed that the return line had turned red on the map, it went back to green after i cancelled RTH, i then tried it several times with the same result ,i very rarely use RTH and thought that it was a feature of the recent update.
Thank you for testing. I really appreciate you taking the time and your results, as it is a vital clue as to what the app
thinks is happening. I haven't updated the app since February. Now I just need to figure out
why it thinks it is in RTH mode, when it really isn't. I'll try activating RTH, as you did, and see if
cancelling it restores the green color. It is a distinct possibility that a signal loss triggered RTH might have gotten stuck, leaving the red line permanently in place! Hmmm...
@wildlifr mentioned it might
also be GEO restriction indication. In retrospect, I was in a unique TFR NFZ just
before I first noticed the color change and couldn't fly, and when the NFZ time expired, flight was restored, but the line has been red ever since. Maybe a GEO TFR glitch residue? How does one completely flush expired GEO residue without completely updating the NFZ database, which might create even more problems than it fixes. I have heard of previous odd behavior when there is a mismatch between an embedded Trojan Horse and current FW which activates it, but not properly!
Still puzzled.
The mystery continues.
Anyone with any other ideas, please share!
